Can I get chart widget to dynamically change when a point is selected on a map?
344
01-23-2026 10:43 AM
Hailey215
I have a map with site points and would like to create a line chart that updates to the corresponding site when it is selected on the map. Is this possible?
AndreasHall
Yes, it is possible. I have done a similar thing for polygons. You need to configure an action on the map that filters the data fed to the chart. The drawback is that the chart need to show all data as default, and data for a specific site first after the user clicks in the map. This was the only solution around a year ago in Enterprise, might be other options available now.
