Can I Export or Print Maps Maps From Experience Builder
5155
7
06-13-2022 07:33 AM
GRmapper
Hello,
I recognize I can allow exporting of information by toggling the capability on and off in the data source pane. But is there a way or widget to allow a user to click a button and create a pdf of a map or list on my EB dashboard?  I can use windows screen capture but was wondering is there was a way inside of EB.
GR
LoganBolan1
This is an idea I would support. I need to be able more to export a report of all projects in a legislator's district, for example, so this is an idea that should be developed a bit further.
GRmapper
Agreed. Having a widget to create something similar to a layout in ArcGIS Pro would be remarkable.
GaryMorris2
You can export a .PNG by adding the "Print Widget"  I have been unable to get it to allow you to export a PDF thus far; something I really need.
ShengdiZhang
Hi @GaryMorris2 ,
If your print service supports PDF format, you can add pdf in the print template configuration:
Shengdi
GaryMorris2
This is great; thank you!
amarcz_cc
Is there an option to Default to PDF? Instead my users have to toggle PDF from the default of PNG32
Brett_Adie
Good day
I have an additional part to this question. When i add the print widget i can only seem to set it to print the map, i want to include a number of the added widgets (excluding the print). How do i do this? what settings etc must i use?
regards
