calcite module in offline environment
1965
8
05-27-2025 08:33 AM
baohuachu7
In offline environment how to set calcite module for the Exb dev version(v1.17)?
There  is no introcution on this topic in the official document.
JunshanLiu
We'll update the doc in the coming release.
baohuachu7
Hi JunshanLiu,
       Follow the steps above, got the problem as below.
Jian8003
Have you copied this folder to your web server? It seems there is no index.js (in your snapshot) file in the folder.
baohuachu7
yes, copied. There is no index.js file in this folder.
JunshanLiu
@baohuachu7 I guess you may use the wrong URL for the "calciteComponentsUrl".
There is a "calcite-components" folder in the "dist" folder, but the "calciteComponentsUrl" should point to the URL you deployed, which does not have the "index.js", but it should have the "calcite.esm.js"
baohuachu7
Hi @JunshanLiu  I think  the "calciteComponentsUrl" is right.  "calcite.esm.js" is linked.
Sujeet
@JunshanLiu  When we deploy calcite on IIS, we get a No 'Access-Control-Allow-Origin' header is present on the requested resource error when trying to create a new project. Any pointers on how we can get around this?
Junshan_Liu
The server that hosts the Maps SDK or Calcite needs to support CORS, see https://developers.arcgis.com/experience-builder/guide/install-guide/#offline-install
