Bookmarks Disable Spacing in Text Widget
944
07-23-2024 01:46 PM
JustinH
I thought I had seen a post before about this but I am not able to find it anymore.
When using a text widget in a bookmark widget, I am no longer able to add spaces between words. I can take the Text Widget out of the Bookmark, type normally, and then drag it back. But if I am to try and add text within the embedded widget, spacing does not work.
Thanks for the help!
Ke_Xu
by Esri Regular Contributor
Hi JustinH,
I could reproduce this issue. The issue has been fixed and will be released in the next version.
Ke
Ke_Xu
Hi JustinH,
Ke
