BookMark widget from another workstation?
949
02-25-2022 04:36 AM
MichaelGinzburg
Hello, I can set up a bookmark. But if I'm getting to the app from another workstation, bookmarks do not work.
Are they stored locally?
Is there a way to share bookmarks?
Thanks!
RobertScheitlin__GISP
@MichaelGinzburg
Bookmarks added at runtime are stored locally on that machine. If you need bookmarks to me globally available to your app then you must add the bookmark(s) at setup of the widget using the "Add Bookmark" button in the widgets settings dialog.
