Bar Chart Labels/Alias
645
02-25-2025 09:24 AM
Sara__
Previously, the bar chart and column chart labels in experience builder would reflect the display name of the web layer.  You used to be able to update and edit the display name through the web map in AGOL and the experience builder charts would also update. Now, the bar chart fields are showing the field names even if the display name is updated. Any reason why this changed suddenly? Any workarounds?
Wei_Ying
Hi @Sara__ ,
Unfortunately I cannot reproduce the problem using my data.
Would you be able to share your app or data for us to take a look?
Wei
