Background color in feature info widget
1379
04-28-2020 08:02 AM
SIG1SMAAG
Hello,
Is it possible to set background color for the "Feature info" widget?
I edited the style.ts file for my custom theme like this:
import { css } from 'jimu-core';
const customGlobalStyles = (props) => {
return css`
.esri-feature__size-container {
background-color:transparent;
export { customGlobalStyles as Global};
But it does not work. See below :
Feature info widget
Tags (1)
by Anonymous User
Not applicable
Since the FeatureInfo widget has its CSS overrides at the widget level, what you can do is to provide a more specific CSS rule such as:
#app .widget-featureInfo .feature-info-component .esri-feature__size-container {
  background: red;
Best,
Yiwei
MatthiasDufour
Thank you very much, Yiwei Ma.
It is perfect !
