Auto Height Setting Not Making Some Blocks Not Render in Moible View
355
01-29-2026 08:55 AM
durus5995
Hello I have an experience builder app that I use for our annual mosquito control conference.  The normal desktop view is working just fine.  However on the mobile view I have blocks in the middle that are not rendering and I think it is due to the auto height setting.  The data and images are there and if I tap and hold I get the popup to download or select the image but all the sections seem to be invisible.  I tried to put different color boarders around the sections to try and see if something in the layout was weird but it did not change anything.
Its kind of hard to explain I can try and provide some screenshots but the link to the experience if you want to check it out.
https://experience.arcgis.com/experience/aeae2b67c63d470bb06998ff4cfb35fb/page/Day-1-Schedule
Any help or suggestions would be wonderful.  Thank you in advance.
durus5995
Well classic "ask for help and immediately find the problem".  So if anyone else has issues with this the solution is to turn off the "Animations" for the entire page.  By default mine was set to "Float In".  Once I changed it to "None" all my blocks loaded perfectly.
durus5995
