Are the anchored or fixed windows moveable?
2283
09-27-2023 12:38 PM
BrandonPrice1
I just wanted to ask here to be sure. I saw where windows can snap to the left or right when it is fixed. There currently isn't a way to move it manually though correct? At the end of this blog article shows a window manually moved to the right but maybe they were using the dev version: https://www.esri.com/arcgis-blog/products/experience-builder/mapping/exb-make-an-in-app-tutorial/
Thanks
ShengdiZhang
Hi @BrandonPrice1 ,
Neither fixed windows nor anchored windows can be moved at runtime. The sample application in the blog post utilizes an anchored window. An anchored window resembles a fixed window in design mode but will automatically adjust its position at runtime to remain alongside its linked widget.
Regards,
Shengdi
BrandonPrice1
Thank you. There also is no way to move them prior to runtime though right? The anchored will always be next to it's associated button and the fixed will always be in the middle?
ShengdiZhang
Hi @BrandonPrice1 ,
For fixed windows, their position can be set through the setting panel on the right side.
For anchored windows, their position will always be automatically set next to their associated widget.
