ArcGIS Experience builder with ArcGIS Dasbboard
379
06-21-2026 03:09 AM
NasratullahOmari
Hi everyone,
Is it possible in ArcGIS Experience Builder to use a Filter widget to also filter an embedded ArcGIS Dashboard?
Both the dashboard and the experience are connected to the same data source, but the filter in Experience Builder only affects the widgets within the experience and not the embedded dashboard.
Has anyone implemented such a setup, or is there a recommended way to achieve this?
JeffreyThompson2
MVP Frequent Contributor
https://doc.arcgis.com/en/dashboards/latest/create-and-share/url-parameters.htm
This can be accomplished by setting up URL parameters in the Dashboard and using the Embed Widget in Experience Builder to Connect To Data and build a URL filter for the Dashboard.
This post should be helpful in getting the two programs to work together and according to my old comments over there, you may need to use the Select Widget as a Filter Widget replacement.
https://community.esri.com/t5/experience-builder-tips-and-tricks/creating-indicators-in-arcgis-dashb...
GIS Developer
City of Arlington, Texas
