ArcGIS Experience Builder- Edit Widget Does Not Support Adding Attachments
2170
07-26-2022 11:05 AM
Amanda__Huber
MVP Regular Contributor
Update- It appears this is only affected when creating new features in EB using the edit Widget. (editing existing features shows the attachment option)
Hello Experience Builder Team,
It appears the the Experience Builder Edit widget does not support adding attachments when editing records. Attachments are enabled on my data, but when editing in EB there are no options for adding in the Edit Widget.
Not in the layer config as a field option:
Unable to add attachments in widget:
Enabled in our data:
Please resolve this issue, thank you.
Amanda Huber
iHack
I'm having the same issue.
HHight
We are also experiencing this. This is extremely frustrating and hinders our ability to edit efficiently.
EDIT:
You can add attachments, but have to enable geometry editing, not just attribute editing. This limitation is still frustrating though.
elpinguino
@HHight this is an issue for us too. Thanks for posting this. Do you know if this has been raised with the developers or if there's any plan/timeline to make attachments available for attribute only. It's too risky for us having geometry editable for the entire org.
