Arcgis Experience Builder 1.5 install pb
2398
08-20-2021 06:14 AM
LionelGOUBET
I am trying to install client and server experience builder 1.5 in my host but when I type npm ci in prompt, it stop with
what's the problem ?
I use node v 16.2.0 under windows 10
Thanks for your help
Tags (1)
LionelGOUBET
ok it works with reboot and add rights in directory
but the client doesn't work
I'm going to try manually ...
TonghuiMing
@LionelGOUBET - Has this been resolved yet? Our team tried using node v16 with dev 1.5 in Win10, and it works fine. Not sure if something else like the browser could affect this - Is there more background information for our reference?
FYI - refer to the recommended node.js versions for each dev edition version: https://developers.arcgis.com/experience-builder/guide/release-versions/
LionelGOUBET
@TonghuiMing  -
Hi, I have to launch the command prompt conosle with no administrator right and this time it ends but I have this error :
D:\ESRI\arcgis-experience-builder-1.5\ArcGISExperienceBuilder\client>nvm use 16.2.0
Now using node v16.2.0 (64-bit)
D:\ESRI\arcgis-experience-builder-1.5\ArcGISExperienceBuilder\client>nvm list
17.0.1
* 16.2.0 (Currently using 64-bit executable)
8.9.4
6.11.4
D:\ESRI\arcgis-experience-builder-1.5\ArcGISExperienceBuilder\client>npm ci
npm ERR! code 1
npm ERR! path D:\ESRI\arcgis-experience-builder-1.5\ArcGISExperienceBuilder\client\node_modules\node-sass
npm ERR! command failed
npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node scripts/build.js
npm ERR! Building: C:\Program Files\nodejs\node.exe D:\ESRI\arcgis-experience-builder-1.5\ArcGISExperienceBuilder\client\node_modules\node-gyp\bin\node-gyp.js rebuild --verbose --libsass_ext= --libsass_cflags= --libsass_ldflags= --libsass_library=
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp verb cli [
npm ERR! gyp verb cli 'C:\\Program Files\\nodejs\\node.exe',
npm ERR! gyp verb cli 'D:\\ESRI\\arcgis-experience-builder-1.5\\ArcGISExperienceBuilder\\client\\node_modules\\node-gyp\\bin\\node-gyp.js',
npm ERR! gyp verb cli 'rebuild',
npm ERR! gyp verb cli '--verbose',
npm ERR! gyp verb cli '--libsass_ext=',
npm ERR! gyp verb cli '--libsass_cflags=',
npm ERR! gyp verb cli '--libsass_ldflags=',
npm ERR! gyp verb cli '--libsass_library='
npm ERR! gyp verb cli ]
npm ERR! gyp info using [email protected]
npm ERR! gyp info using [email protected] | win32 | x64
npm ERR! gyp verb command rebuild []
npm ERR! gyp verb command clean []
npm ERR! gyp verb clean removing "build" directory
npm ERR! gyp verb command configure []
npm ERR! gyp verb find Python Python is not set from command line or npm configuration
npm ERR! gyp verb find Python Python is not set from environment variable PYTHON
npm ERR! gyp verb find Python checking if "python3" can be used
npm ERR! gyp verb find Python - executing "python3" to get executable path
npm ERR! gyp verb find Python - "python3" is not in PATH or produced an error
npm ERR! gyp verb find Python checking if "python" can be used
npm ERR! gyp verb find Python - executing "python" to get executable path
npm ERR! gyp verb find Python - "python" is not in PATH or produced an error
npm ERR! gyp verb find Python checking if "python2" can be used
npm ERR! gyp verb find Python - executing "python2" to get executable path
npm ERR! gyp verb find Python - "python2" is not in PATH or produced an error
npm ERR! gyp verb find Python checking if Python is C:\Python37\python.exe
npm ERR! gyp verb find Python - executing "C:\Python37\python.exe" to get version
npm ERR! gyp verb find Python - "C:\Python37\python.exe" could not be run
npm ERR! gyp verb find Python checking if Python is C:\Python27\python.exe
npm ERR! gyp verb find Python - executing "C:\Python27\python.exe" to get version
npm ERR! gyp verb find Python - "C:\Python27\python.exe" could not be run
npm ERR! gyp verb find Python checking if the py launcher can be used to find Python
npm ERR! gyp verb find Python - executing "py.exe" to get Python executable path
npm ERR! gyp verb find Python - "py.exe" is not in PATH or produced an error
npm ERR! gyp ERR! find Python
npm ERR! gyp ERR! find Python Python is not set from command line or npm configuration
npm ERR! gyp ERR! find Python Python is not set from environment variable PYTHON
npm ERR! gyp ERR! find Python checking if "python3" can be used
npm ERR! gyp ERR! find Python - "python3" is not in PATH or produced an error
npm ERR! gyp ERR! find Python checking if "python" can be used
npm ERR! gyp ERR! find Python - "python" is not in PATH or produced an error
npm ERR! gyp ERR! find Python checking if "python2" can be used
npm ERR! gyp ERR! find Python - "python2" is not in PATH or produced an error
npm ERR! gyp ERR! find Python checking if Python is C:\Python37\python.exe
npm ERR! gyp ERR! find Python - "C:\Python37\python.exe" could not be run
npm ERR! gyp ERR! find Python checking if Python is C:\Python27\python.exe
npm ERR! gyp ERR! find Python - "C:\Python27\python.exe" could not be run
npm ERR! gyp ERR! find Python checking if the py launcher can be used to find Python
npm ERR! gyp ERR! find Python - "py.exe" is not in PATH or produced an error
npm ERR! gyp ERR! find Python **********************************************************
npm ERR! gyp ERR! find Python You need to install the latest version of Python.
npm ERR! gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
npm ERR! gyp ERR! find Python you can try one of the following options:
npm ERR! gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
npm ERR! gyp ERR! find Python (accepted by both node-gyp and npm)
npm ERR! gyp ERR! find Python - Set the environment variable PYTHON
npm ERR! gyp ERR! find Python - Set the npm configuration variable python:
npm ERR! gyp ERR! find Python npm config set python "C:\Path\To\python.exe"
npm ERR! gyp ERR! find Python For more information consult the documentation at:
npm ERR! gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
npm ERR! gyp ERR! configure error
npm ERR! gyp ERR! stack Error: Could not find any Python installation to use
npm ERR! gyp ERR! stack at PythonFinder.fail (D:\ESRI\arcgis-experience-builder-1.5\ArcGISExperienceBuilder\client\node_modules\node-gyp\lib\find-python.js:302:47)
npm ERR! gyp ERR! stack at PythonFinder.runChecks (D:\ESRI\arcgis-experience-builder-1.5\ArcGISExperienceBuilder\client\node_modules\node-gyp\lib\find-python.js:136:21)
npm ERR! gyp ERR! stack at PythonFinder.<anonymous> (D:\ESRI\arcgis-experience-builder-1.5\ArcGISExperienceBuilder\client\node_modules\node-gyp\lib\find-python.js:200:18)
npm ERR! gyp ERR! stack at PythonFinder.execFileCallback (D:\ESRI\arcgis-experience-builder-1.5\ArcGISExperienceBuilder\client\node_modules\node-gyp\lib\find-python.js:266:16)
npm ERR! gyp ERR! stack at exithandler (node:child_process:333:5)
npm ERR! gyp ERR! stack at ChildProcess.errorhandler (node:child_process:345:5)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:365:28)
npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:288:12)
npm ERR! gyp ERR! stack at onErrorNT (node:internal/child_process:480:16)
npm ERR! gyp ERR! stack at processTicksAndRejections (node:internal/process/task_queues:83:21)
npm ERR! gyp ERR! System Windows_NT 10.0.19043
npm ERR! gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "D:\\ESRI\\arcgis-experience-builder-1.5\\ArcGISExperienceBuilder\\client\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" "--verbose" "--libsass_ext=" "--libsass_cflags=" "--libsass_ldflags=" "--libsass_library="
npm ERR! gyp ERR! cwd D:\ESRI\arcgis-experience-builder-1.5\ArcGISExperienceBuilder\client\node_modules\node-sass
npm ERR! gyp ERR! node -v v16.2.0
npm ERR! gyp ERR! node-gyp -v v7.1.2
npm ERR! gyp ERR! not ok
npm ERR! Build failed with error code: 1
Apparently I have to make npm config set python "C:\Path\To\python.exe" but what the consequences ?
Thanks
BolanChen
@LionelGOUBET You can try to manually install a global node-gyp, in fact, the node version recommended for exv dev 1.5 is node14
