How do I remove an added utility from the analysis widget? I don't mean "remove the tool", I mean "I do not want this utility to show up in this list anymore" (see panel on the left).
If you don't need the data at all, you could remove on the data tab?
Looks like it's the Utilities tab. Thanks!
Yep, sorry read to quick and thought a "utilities" data layer. Anyway glad it worked.
