AGO Experience Builder Analysis Widget
10024
23
03-01-2024 07:49 AM
BrettMartin1
We have a public geoprocessing service in this AGO application in WAB. I have been testing the most recent updates to the Analysis Widget in Experience Builder. The ability to draw the input parameter on the map is a great improvement. However, the widget is still missing functionality that is available in the WAB Geoprocessing Widget. The input configuration is missing “use current map extent” for the extent parameter. There are not options for configuration of output popup or symbology.
The major issue we have found is there is no way to configure the widget to not create a feature service. In WAB if I uncheck “Visible”, the results are added to the map and not too AGO My Content.
In Experience Builder, there is no option in the builder. The hint in the app GUI states if left blank a feature service will not be created.
However, if left blank the tool fails.
MarcusRademaker
@Wei_Ying Here is the URL: https://portmapsacc.ad.portofrotterdam.com/porags6/rest/services/UpdateFeatures2/GPServer
However, maybe you cannot enter it due to our firewall. In that case, what's your email address?
Wei_Ying
Hi @BrettMartin1 ,
I have logged an enhancement request for controlling parameter visibility of custom tools.
Wei
BrettMartin1
Hello @Wei_Ying
The tool is now working! However, after testing several other tools I have several new requests. We had the ability to configure the output pop up in WAB.
Also, I love having the ability to have multiple GP services in one widget. However, can we get an option to edit the names of the tools? Seems to be pulling straight from service name.
Wei_Ying
Hi @BrettMartin1 Thanks for the feedback. For your request.
So far we don't have that plan. But in future we may enhance to support.
We are working on enhance to rename the tool label.
Wei
BrettMartin1
I see we can change the name of the tools now, thank you.
We need the ability to configure the pop up of the output.
More importantly we need to same options from WAB for the extent parameter. Currently users will have to draw a polygon for the extent of processing since "current map extent" is not an option like WAB.
Wei_Ying
Thanks for you feedback. We will try to support these features in future releases.
BrettMartin1
Thank you for getting back so quickly. I have one more request. The tool will run with "Output Feature Service Name" blank. Which you all fixed and previous release. However, if I enter a service name while logged into my AGO account, I get the error below. Can have an option to make "Output Feature Service Name" not visible. This was an option in WAB. This is very confusing for public users to tell the not to populate the text box.
The export results is also limited from the options in WAB. The "save my content" was very useful for users who do have AGO accounts and use ArcGIS Pro.
The "Allow drawing on the map" is also not optimal. In WAB the widget recognized my feature set parameter was a point and only gave the option for a point in the tool. EB gives all the option below which is also confusing for public users.
JeffLegato1
YES! I need this. Having to explain to my users to NOT enter a value is not good.
BrettMartin1
@JeffLegato1  they fixed this one a few updates ago. You can now leave not visible and there are no errors.
JeffLegato1
@BrettMartin1 Thank you! Good to know! We are still on 11.1. Planning our update for January.
