Adding widgets to a collapsible widget
2081
04-03-2022 04:55 AM
vtey_esriau
Hi using the elevation profile widget as an example, Is it possible to add widgets to a panel that is collapsible? Similar to the old WAB attribute table. Some that can be toggle on and off?
Cheers
Victor
Grant-S-Carroll
Have you seen the sidebar widget? This is a collapsible layout widget in which can you can place a widget and allow the user to open or close.
https://doc.arcgis.com/en/experience-builder/configure-widgets/sidebar-widget.htm
