Add Data Widget Not Supporting Group Layer Item
1848
01-09-2024 05:26 AM
TimF
Hello,
We would like to take advantage of the Group Layer Item functionality that was introduced last year (blog post here) but we're finding that the Experience Builder 'Add Data' widget doesn't appear to recognise them.
A 'Group Layer' item in My Content:
No result when searching for it in the Add Data widget in EB (ArcGIS Online):
I'm assuming this is because 'Group Layers' aren't supported. Is this functionality likely to be added, and if so is there a timeline for it?
Tagging @AlixVezina as I have seen other queries on Group Layers that you have replied to, but nothing for the Add Data widget specifically.
Thanks!
AlixVezina
Hi @TimF , thank you for your question!
This is currently a known limitation and is on the roadmap for the upcoming update of Experience Builder.
AlixVezina
TimF
Perfect, thanks for confirming!
ECJRIJS
I was wondering if there is any update on this topic as I have a bug to report.
Within the add data widget I am able to add group layers. However, the added group layers do not have the configuration (Names, visibility scale) as set up in the mapviewer for the grouped layer.
If necessary I can make a seperate post about this.
