Add Data Widget - does it work?
2324
01-05-2024 12:09 PM
ChrisMyers_NewQuest
I'm trying to utilize the "Add Data" widget in Expereince Builder, but it doesn't seem to be working. I'm trying to determine if it's the widget or my own user error.
The workflow I need to account for is someone exporting a .kmz or .kml file from Google Earth, and for them to be able to add the data to an expereince builder.
I've tested with multiple files and have not has success. I don't receive any error message, and the data is added to the "Add Data" legend, however it never shows on the map.
KenBuja
MVP Esteemed Contributor
Did you also click the Action button and select "Add to map"?
ChrisMyers_NewQuest
@KenBuja I do not see that option, only "Set Filter" or "Export". Could this because the .kmz is a georeferenced site plan, not vector data?
KenBuja
It seems to have a problem with kml files (kmz files don't seem to be supported). I can add a kml file to the Web AppBuilder Add Data widget and it shows up as expected, but I just get the Set Filter and Export options using the Experience Builder widget
