Add data widget and upload file as csv ,zip
1667
08-31-2023 01:26 PM
HariomPandya
Hi in the add data widget od experience builder where we can upload the shapefile as zip ,csv or kml file . now inside this widget there is some llimitation for file size and maximum data counts or record . something 4000 for shapefile and same limitation for csv . Now my question is that can i able to configure the code to change this limitation to increase the number of records and all . if this is possible then how  . please help its urgent .
TianWen
This is a limitation of the underlying interface used by the Add Data widget, and unfortunately, there is no known resolution for now.
TonyC
I just tested dragging zipped shape files into the Add data widget and find the limit is 999.  4000 would be nice - I need it to work for 1500-2000.  Has ESRI reduced this limit?
