Add an array of client-side features to StreamLayer
904
03-18-2023 02:30 PM
MarkEgge2
I'm using a widget to add a StreamLayer to a map.
If I add a StreamLayer from a StreamServer, everything works fine. E.g.
const layer = new StreamLayer({
    url: 'https://geoeventsample1.esri.com:6443/arcgis/rest/services/LABus/StreamServer',
If, however, I create an array of client-side features and use layer.sendMessageToClient({ type: "features", features: [ ... ]}) the features do not display on the map.
Here's a CodePen of a working version (outside of Experience Builder).
Here's my widget.tsx:
import { React, AllWidgetProps } from 'jimu-core'
import { JimuMapViewComponent, JimuMapView } from 'jimu-arcgis'
import FeatureLayer from 'esri/layers/FeatureLayer'
import StreamLayer from 'esri/layers/StreamLayer'
const { useState } = React
const Widget = (props: AllWidgetProps<any>) => {
  const [jimuMapView, setJimuMapView] = useState<JimuMapView>()
  const activeViewChangeHandler = (jmv: JimuMapView) => {
    if (jmv) {
      setJimuMapView(jmv)
  // Create the StreamLayer
     fields: [
        alias: "OBJECTID",
        type: "oid",
        alias: "TrackId",
        type: "long",
    timeInfo: {
      trackIdField: "TRACKID"
    geometryType: "polygon", // required property
    spatialReference: {
      wkid: 102100
    renderer: {
      type: "simple",
      symbol: {
            type: "simple-fill",
            color: [233, 116, 81, 0.5],
  let objectIdCounter = 0
  const addLayer = () => {
    // Add the layer to the map (accessed through the Experience Builder JimuMapView data source)
    jimuMapView.view.map.add(layer)
  const addFeatures = () => {
      type: "features",
      features: [
          attributes: {
            TRACKID: 1,
            OBJECTID: objectIdCounter++
          geometry: {
            rings: [[
                    [-12475988, 3965039],
                    [-12476958, 3965047],
                    [-12475991, 3966004],
          attributes: {
            TRACKID: 2,
          geometry: {
            rings: [[
                   [-12475020, 3963094],
                    [-12475019, 3964062],
                    [-12474046, 3963093],
  return (
    <div className="widget-starter jimu-widget">
        props.useMapWidgetIds &&
        props.useMapWidgetIds.length === 1 && (
          <JimuMapViewComponent
            useMapWidgetId={props.useMapWidgetIds?.[0]}
            onActiveViewChange={activeViewChangeHandler}
      <button onClick={addLayer}>Add Layer</button>
      <button onClick={addFeatures}>Add Features</button>
    </div>
export default Widget
Is this a bug with the new array of client-side features for StreamLayers? (Alternatively, is there a better approach if I want to change the values in a DataSource using logic in the widget and then have the symbology on the map update accordingly?)
Tags (3)
