Add 'alt text' for image attachments in Feature Info widget
1277
11-08-2023 09:41 AM
Trippetoe
Hello.
Is there a way to add 'alt text' to image attachments that are included in a Feature Info widget? If so, is there a way to dynamically assign a data source field as the source of the alt text depending upon the user's language settings in the browser?
Thank you.
Wei_Ying
Hi @Trippetoe ,
No the Feature Info widget in ExB does not support to add 'alt text' to attachments or further editing.
Feature Info just honor the popup setting of a feature layer.
You may look into solution from the popup setting from map view. You can try do customization of attachment format or probably use Arcade express to do dynamic setting.
Wei
