Table Widget
1607
04-14-2021 12:42 PM
Status: Open
smay_gis
Hi! I have researched this and don't believe anyone has asked it or brought it up...
I am wanting to use the table feature like the attribute table widget in WAB. This means I want the the attribute table to refresh to the map extent. I don't think this is possible.. at least yet? I am hoping a future update will include this. I have it currently updating with "selection", but I would prefer it to just update itself with the map extent. It is a little tedious.
Also, there is a ton of white space in between the tabs in the table and the actual information without the search option. I feel like the appearance of the widget should be more customizable? Thanks!
3 Comments
TianWen
Hello! Thanks for the comments!
Currently, "filtering table records by map extent changes" can be realized by exploiting the message/action mechanism.
Follow the steps as below:
1. Add an "extent changes" trigger to the map widget
2. Make the trigger target the framework
3. Set the action "filter data records"
4. Select the data you would like to use
Then you should be able to filter the table records by navigating/zooming the map!
And we'll consider your suggestion regarding customizing the appearance.
Thank you,
Tian
smay_gis
Thank you @TianYu ! However, I have already done this. It is filtering my text widgets, but not my table.
In this example I am zoomed to Reagan County ONLY, and Upton and Midland (as well as all other data) are still showing. Do I need to update somehow? I reviewed all my triggers and they are done how you suggested.
Joshua-Young
@TianWen any update on the filter by extent coming to the table widget in Experience Builder. ArcGIS WebApp Builder was just retired, and I moved most of our main apps to Experience Builder only for my users to point out that this functionality is not there in ArcGIS Enterprise 11.3.
The recommended work around is not great for our use case because my users alternate between viewing all the records and filtering to the extent when needed. Using the map trigger makes it always on with no way for the user to turn off.
