Support proxy configuration in ArcGIS Experience Builder Dev Edition for local development
1443
07-15-2025 05:55 AM
Status: Open
RyanTaylor
During local development the experience is hosted on https://localhost:3001 per the typical ExB installation and our backed API is hosted on https://localhost (or another domain). However, the Integration, Acceptance, and Production frontend and backend deployments are all deployed on the same domain, e.g., https://mydomain.com/myapp.
When calling our custom backend API we use known relative paths — e.g., fetch("api/weather") — as we prefer convention over configuration. However, this isn't workable as without a proxy the frontend sends requests to https://localhost:3001/api/weather rather than https://localhost/api/weather.
To support this in our custom non-ExB apps we utilize webpack-dev-server's proxy configuration. It appears the ExB Dev Edition uses Koa to serve the application. It would be very helpful it ExB Dev Edition supported the configuration of a local proxy similar to webpack-dev-server's proxy. A quick search shows that Koa has a proxy middleware (koa-proxy) that may be of use. Ideally, we could include a koa-proxy.js (or json) file to configure our proxy info.
This would make ExB Dev Edition more developer friendly; we would not need to code special logic for the dev only scenarios.
3 Comments
NHannig
1000%, this would help a lot with development!
LucVanDijk
I greatly support this idea! The use of proxies was supported in WAB and it would be helpful to have it in the ExpBuilder too
NHannig
I hope ESRI works on this
