Selection Tool in Edit Widget Improvements
323
05-27-2026 01:53 PM
Status: Open
Labels (2)
ChristineCarrelliAD
When the Edit Widget is in 'Attribute Only' mode there are no selection tools in the widget for the user to select features.  Please add an option in the Edit Widget configuration to add a selection tool when in 'Attribute Only' mode.
Also, please add a configuration option to set the default tool in the Edit Widget when in 'Interact with a Map widget' mode.  Right now it is defaulting to 'Pan', which requires an extra step for the user each time they edit to first select the selection tool in the Edit widget before they can edit.  This isn't an issue if your end user only edits once or twice a day, but if you are doing lots of edits throughout the day it is painful for the end user (especially since I am trying to replace a Web App Builder app and the new Experience Builder app is not as good as the original).
It would also be helpful to return the app to the original cursor mode when the Edit Widget is closed and unselect any selected features.  Right now it is often still in 'Select' mode' when the widget is closed and then the feature popups no longer appear and they are stuck in selection mode until they open the edit widget again and turn off the Select tool (this is not intuitive for the end user).   The users are finding it a struggle to get back to Popup/Identity mode and to clear selected features.
It would also be useful to have a clear selection option in the Edit Widget along with the pan tool etc.
