Search widget in Experience Builder can only flash 1 layer used in a composite locator.
2231
05-20-2024 11:55 AM
Status: Open
Labels (2)
JeffLegato1
In Enterprise 11.1, the search widget in Experience Builder can only flash a result from one layer (and only one field) used in a composite locator. Our locator can find address points, streets, street intersections, addresses along a street if no direct match, and assessor parcel numbers in 9 character and 11 character formats. The search widget can only be configured to flash one of these results. The Trigger / action connection is limited and doesn't seem to function as designed.
For example, when I use this locator with the Experience Builder search widget I can only get either the address point OR the parcel to flash on the map. I've had several calls with ESRI technical support trying to figure out a way to get multiple result types to flash but to no avail. A work around was proposed by the technical specialist to flash for one and select for another but that isn't what is needed and that only covers two result types.
2 Comments
ShengdiZhang
Hi @JeffLegato1 ,
Can you share with me a sample app that includes the layer and the composite locator service? I want to take a closer look.
Thank you,
Shengdi
JeffLegato1
Thank you @ShengdiZhang . I sent you a direct message.
