Reorder table fields when using layer settings in Experience Builder
1081
04-29-2025 10:08 AM
Status: Open
yli
In web map viewer, I'm able to set up field properties such as decimal points. However, in Experience Builder, when a table uses layer settings (i.e., field properties set in web map viewer), I cannot change the order of table fields. All the fields are showing based on alphabetic order and there's no way to change it. If I let the table use custom settings instead of layer settings, I can change field order by dragging the fields, but all the field properties set up in web map viewer are not available. I wonder if there's a way for users to change the order of table fields when the table uses layer settings. Thank you!
1 Comment
Shen_Zhang
Hello @yli, thank you for raising this idea.
The "Use layer settings" mode was designed to allow users to set up a table sheet effortlessly without too many configurations on the fields. The displayed fields order honours the settings in the map viewer popup, then the layer settings. Please let me know if you see issues regarding this.
To solve your problem, we've handled the thousand separator for the numeric fields in "Customised" mode. These field formats will now display as you set them in the MV popup (will be available in the upcoming ArcGIS Online June release). However, there is still an outstanding issue regarding the date/number format, which we're working on fixing from the Maps SDK side.
