Remove geoprocessing history from Analysis widget in Experience Builder application
905
09-27-2024 12:29 AM
Status: Open
Labels (2)
HarleyDavidson
When running the Analysis widget within the Route template in ArcGIS Experience Builder, the geoprocessing results remain in the History tab even when the application is closed. At the moment, it is only possible to remove the geoprocessing results manually. However, if the application is being used by multiple end-users the History tab will become very cluttered/busy. It would be ideal if the geoprocessing history is cleared on closure on the application.
1 Comment
DougBrowning
I need this also.  It seems to be remembering inputs across sessions also which is driving us nuts.  It also seems to get stuck on the return job numbers and starts giving bad URLs.  I removed all internet files and it is still remembering somehow.
