Option to deactivate editing mode in the Edit widget
2061
04-19-2024 01:54 AM
Status: Open
KamilNovák
We would appreciate the ability to disable "edit mode" in the Edit widget in ArcGIS Experience Builder once the user has completed their edits.
Currently after editing the first feature with the Edit widget, the next selected features are in editing mode even if the Edit widget is closed. There is no such option, which can be inconvenient for users who just want to view popups without accidentally moving their polygons etc.
This issue is also discussed in the same topic: https://community.esri.com/t5/arcgis-experience-builder-questions/how-do-i-deactivate-the-edit-featu...
Thank you.
3 Comments
lah
Yes. The user experience for editing within Experience Builder is horrible. My users are accidentally changing geometry and moving things around without realizing it.
Ideally, the edit pane should function similarly to Map Viewer. If the edit pane is closed, editing should be disabled.
KamilNovák
@lah, I think this feature is now available in the ExB Developer v. 1.15 and ExB in ArcGIS Online now. You need to place Edit widget in the Widget Controller for it and then it should work exactly as you describe.
RVRAdmin
It's March 2025 and Edit widget in a Widget Controller does not stop/close editing mode. Once the edit widget is opened, geometry edit mode stays on whenever a polygon is clicked on, even after closing the Edit widget and opening other widgets. The only thing that "turns off" editing mode is refreshing the browser window...
