We are a local authority and have an experience builder application containing a number of views that correspond to a specific data theme and link to an individual web map. Each view presents a map view as well as contextual information specific to that data them, including text and charts.
Users use this application to view these data themes at a street or property level. However, when changing views, the zoom level and map position changes/resets to the default zoom level for the map view, which is the full extent of the local authority.
It would be useful to have the option to be able to maintain the zoom level and map position between views. This would allow users to view a range of data themes at a street or property while being able to change between views and have the information ready to them, without needing to zoom back into and navigate to the area of interest.
This should already be supported. In the Map Settings Panel, add a Extent Changes > Other Map > Zoom To Action. Then repeat so that every Map sends it's extent to every other Map.
To add to Jeffrey's post, here is an article that has a detailed workflow that might help : https://support.esri.com/en-us/knowledge-base/how-to-synchronize-the-map-extent-of-multiple-map-widg....
