Image Widget Position - Add None To Fit And Fill
1104
03-15-2021 11:10 AM
Status: Open
DaveFullerton
This is specifically an issue when the Image Widget is in a Widget Controller.  Setting the Image Widget's height and width to Auto seems to do the trick otherwise.
I imagine that there are plans for building a much more configurable dynamic Legend Widget someday for ExB, but the way things work right now the legend widget just doesn't work well enough in some cases. Sometimes a static image works better. I don't know how often the Image Widget is used within a Widget Controller, but we use it that way for showing legend images. The complaint I got was that the image looks fuzzy:
image.pngimage.pngFuture Development Plan Two Column.PNGFuture Development Plan Two Column.PNG
It would also be really nice if the pop-up would open at the size that would show the entire image.
