Get and Update dependencies (data sources) for an experience builder app using Python API: Full mapping
1120
03-20-2026 02:36 AM
Status: Open
TjibbeWubbels
Issue
Updating data sources used in an Experience Builder app using the ArcGIS API for Python is difficult. The app might have multiple web maps or feature layers as dependencies. And many widgets reference these web maps or layers and have to be updated individually. You can use:
exp = WebExperience(item="{my id}")
print(exp.datasources)
to see the datasources and statements like:
exp.datasources['dataSource_1']['itemId'] = "{some id}"
exp.datasources['widget_11_output']['schema']['fields'] = {fields dict}
to update your data sources.
But after updating the datasource used a widget, the widget no longer loads: "Data is inaccessible".
The configuration of the widget in the data.json of the experience still shows the old datasource, and the old fields. So you would need to collect the data.json, update it and save it again to also fix this.
Proposed change
I propose to have one place to view and update all dependencies, exposed through the ArcGIS API for Python. Updating datasources (including field names) here, will update them everywhere they are used in the experience.
Background
At the Esri Developer & Technology Summit 2026 the new arcgis.apps.dashboards module was announced. It features the possibility to get dependencies and update dependencies for a given dashboard. Updates are done throughout in dashboard, in all components and even arcade expressions. Please add this functionality to the arcgis.apps.expbuilder as well.
Use cases
- Copy an existing experience and update the data sources used in the experience programmatically
- Fix a broken experience by updating a web map id, layer id, and/or field name
3 Comments
TimWestern
I get you are asking about something in python, experience builder is NodeJS (Javascript/Typescript)
How would that help people using Experience builder?
It would be nice to not have to manually change strings.
IN a lot of custom widgets we end up creating a very detailed settings file where each source has to be manually set, which means when you move guess what have to be set so its still manual that way
TjibbeWubbels
Thanks for your feedback @TimWestern . I updated the first line of my idea to stress that this is indeed about functionality in the ArcGIS API for Python.
The idea would help developers that are using the ArcGIS API for Python in automating creating and updating of Experiences.
For the Experience Builder application itself, it would also be helpful when the widgets would be updates if you update the data sources. I'm not sure if that is the case or not (I'm using Python).
ODWC_GIS
Hi there.  I am currently stumbling around a Python Notebook, attempting to use the ItemGraph to .remap_data() of an Experience by substituting one Map for Another.
I can't tell how well it has worked.  As I now have an Experience containing Both Maps.
I think @TjibbeWubbels may be referring to this general state of affairs.   Something inside the Experience is probably referencing the initial Map via some relationship-or-other that didn't get the remap_data() update.
Being able to manage the interconnected nightmare that is Experience Builder by using a simplified GUI would be very much appreciated.
