Filter Widget - Option To Allow Only One Filter To Be Applied At A Time (radio buttons)
6925
15
03-10-2021 11:04 AM
Status: Open
DaveFullerton
For our use case, these are our filters:
As you can see, it wouldn't make sense to apply more than one at a time, and applying the first two at the same time filters out all of the data. You can try this out here:
http://map.opkansas.org/find-a-development-proposal/
15 Comments
SamSchiller_work
So are we all still waiting for a solution, then? I have several filters which display varying emission/timeframe scenarios for climate data. Right now, I have a text box next to my filters instructing the user to only activate one filter at a time as to not break the display. Would love to have the filter widget adjusted so we can set a rule saying "only one filter allowed" or "deactivate previous filter when new filter is toggled on."
CherieBryant
Same problem here. I also want to filter where only 1 year of data shows at a time. The Timeline widget needs updates to better support annual data  - first thing being the line at the top of the widget shows the beginning & end time down to the millisecond. It is the first element of the map to draw the user's eye & confuses them. The filter option for each year would be ideal if there is an option to have only one active at a time like in Dashboards. Looking forward to trying the proposed workaround from @DickieRigdon.
TomasPokorny
WFCAdmin
Having the same problem. It would be great if there were an option to have each filter deactivate all other filters when selected.
ebrays
Hi - Would really appreciate this functionality. There are ways around it but they're convoluted and can make the experience worse for the user than just having an option for setting filters as mutually exclusive. Thanks.
