Feature Request: Enhance measurement widget
1179
06-20-2024 08:30 AM
Status: Open
ClintOffutt
Hi, could you please add functionality to the measure tool on Experience Builder?  Or create a new widget with advanced, configurable features?
We need to be able to set default units.
We need to be able to measure and log indiviudal segments within a multi segment linear measurement.  ArcReader did this.  Instead of just adding to the previous segment, at a most basic level, at least restart the measurement.  Ideally, when you click a new segment, the previous segment creates a label with that measurement, then you click again, and it labels that piece, etc.  We could also a log or list, but on screen mapping labels would be better.  It would be nice if each time you are drawing a linear segment with the measure tool for it to dynamically "label" or show that measurement, then when you click it locks it in on screen.
We also need multiple measurements to be on the screen at once.  Instead of clearing the old when starting a new, keep them on screen until a clear button is pressed.
Please add these features, or reply back if you need more instruction.
thanks,
--clint o
3 Comments
bw_gtg
Agreed on everything!
JBH
Yes please!
JustinSmith9
In the U.S., a common request is that the in-map measure widget in ExpB be made configurable so it can be set to feet and acres as the default.
