Export data table with description value, not coded value for fields with domains
4348
11
08-25-2022 01:10 PM
Status: Implemented
LeeBrannon1
When using the Export Records action of the Feature Info widget, the exported CSV file shows the codes and not the descriptions for fields that have domains.  The default export behavior should output the description instead of the code for those fields, as it does in Web AppBuilder applications.  Currently, with Experience Builder, there appears to be no way at all to get the attribute descriptions into the output table.
The soon-to-be users of the application that I am developing with Experience Builder have explicitly requested the ability to export all of the records in the data to a file (must be a non-proprietary format).  Those users will not be able to do their analysis if they receive the domain code values instead of the descriptions.
11 Comments
Adam_Bourque
@ShengdiZhang is there any possibility to add function can choose whether user wants codes or labels for export on experience builder? The advantage to having it on experience builder is re-arranging the table for certain workflows. I realize I can export from source feature layer for codes but that only honors original field order from database.
Thank you
