Enable ability to move map tools anywhere.
5167
13
11-01-2023 12:51 PM
Status: Open
Labels (3)
JonathonMerrick
Currently in EXB, you have two choices of where you can place the map tools (zoom, home, locate, compass, etc.).  Enable the ability to move each of the map tools independently of each other, add them to a widget container, or re-order them in any way.
^ Current options for map tools location ^
Also, the measurement tool is seemingly shunned by the other tools as it appears opposite the location of the zoom/home/locate tools. Allow moving, stacking, or ordering the tools in whatever way we desire.
^ Two options for Measure tool location, neither of which is desirable. ^
Current options
13 Comments
Ke_Xu
by Esri Regular Contributor
Hi All,
Thanks for your feedback. We are working on it.
These map tools have corresponding widgets, listed below.
Tool nameWidget namePortal version                Developer Edition
LayersMap Layers10.8.11.0
 Legend10.8.11.0
SearchSearch11.0 1.6
BasemapBasemap Gallery11.21.12
SelectSelect11.31.14
LocateMy Location11.41.15
MeasureMeasurement11.41.15
Ke
SheenaBroom
I too am adding my voice as to be able to move the "Home","Zoom" and "Extent" buttons would makt the Mobile layouts much more workable. Currently I cannot move them away from bottom of the map/screen, they get obscured when the Table, Pop up or other widgets (eg Layers) are pulled up from the bottom section.
Ke_Xu
Hi All,
This feature has been released on ArcGIS Online in February 2026 and will be available with ArcGIS Enterprise 12.1.
You can customize the map tool layout on large and medium screen devices. The mobile layout will be more complex; we’ll further investigate the solution.
Ke
