Edit Widget - Choosing the Asset Title to display by Attribute
1186
08-23-2022 01:36 PM
Status: Open
Labels (2)
MattBell2
In setting up the Edit Widget in Experience Builder, it would be nice to be able to select which attribute/field you would want to see as the title of the asset you plan to edit.  It is my understanding that this currently can only be set in ArcGIS Pro.
3 Comments
AlixVezina
Right now the only way to do this is by updating the Display Field as specified in this article: How To: Change Display Field Using ArcGIS Server Services Directory REST API (esri.com)
Thanks for logging this request @MattBell2 .
KKelechenyi
I'm in a similar position regarding the display field. In my case, I would like the suggestions in the search widget to use a field that I select instead of the display field. Is this ability on the horizon?
AlixVezina
@KKelechenyi Please, would you be able to provide more details on what you are trying to achieve?
