Clear widget framework filters
622
07-09-2025 09:44 AM
Status: Open
Labels (2)
ArianaToth
It would be great if I could have a widget (I'm using a chart) be able to have an action set to filter the framework, and then also be able to clear that filter.
Right now I have dashboard that I've built in Experience Builder. It contains a map, a chart widget and a couple of list widgets. I would like to be able to select category in my chart and have it filter my list. That part works, but there is no option to clear that filter without reloading the page. (I'm currently using this workaround: How To: Display Feature Records in the List Widget Based on Selected Features in ArcGIS Ex.) But it would be a lot easier to just have the Clear Selection button on the Chart widget work to clear both selections and filters. End users should have the ability to clear all filters that they trigger within the app.
1 Comment
Wei_Ying
Hi @ArianaToth
"but there is no option to clear that filter without reloading the page"
It should be supported if you click the clear selection button. May I know which version are you using? If the filter does not clear it sounds like a bug. Can you share more information?
