Buffer Widget Experience Builder
10769
13
11-16-2023 11:21 AM
Status: Open
Labels (2)
JorgeMorteo
This is no believable. The Buffer widget in Experience  Builder only buffers from a point.  The basic geometric shapes use in GIS are points, lines and polygons. The buffer tool is useless if it can not buffer from the geometric features.  Please have the buffer tool buffer from Polygons and lines too. There is a web app builder tools that works great but it is not available in Experience Builder "Public Notification" . Make the buffer tool do the same please.
13 Comments
AValenski
@JorgeMorteo are you referring to the Analysis Widget's buffer within ExB?
JorgeMorteo
The actual widgett name is the "Query Widget"  but ESRI said that the intent was not to display a buffer but to get attributes .
In web app builder the "Public Notification" works good but it does not work the same way in Experience builder.
Experience builder should have a buffer widget. Planning departments in the USA use it often  to see distances from certain land uses to  protected uses such as schools, child cares ....
NedCake1
This is another instance where ESRI has not reached parity between WAB and Experience Builder.
We need a widget that will create a buffer around a selected feature(s), display the buffer on the map, then select features that intersect the buffer, and allow users to export the selection.
You want us to migrate to EXB but the tools simply are not there.
P.S. Instant apps is not a workable solution to this need.
Bec
I agree with the many commenters above me.  We need a Buffer Widget for Experience Builder.  It would be nice to have something similar to what they have in the below image for this website: https://property.franklincountyauditor.com/_web/maps/mapadv.aspx
JorgeMorteo
Thank yo for sharing the website. I will be going to the ESRI conference in a few weeks and I will find out more about it.
paleo999
You would think a simple buffer widget would be one of the first things to be implemented in Experience Builder.
JorgeMorteo
FYI The "NEARME" widget works just like the buffer tool.
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/near-me-widget.htm
RyanH1
Did ESRI provide any additional information about plans to offer a buffer widget at the User Conference?
JorgeMorteo
Yes and No.  The NEARME widgett is the Buffer tool.  They just called "NEARME"
AlixVezina
You can use the Analysis widget to create buffers around features (points, lines, and polygons).
