Bookmark Widget: ability to turn off zoom-to-extent aspect of bookmark
1540
02-03-2025 01:51 PM
Status: Open
Labels (2)
TaraHaynes
Idea:
The Bookmark widget is great for allowing different themes to be viewed on one source map. However, I would like to allow the user to choose their extent and view different themes within that extent, rather than the map zooming to the pre-set bookmark extent every time.
Workflow context:
Dataset: species data containing 7 themes; Natural Resource Region (NRR), Population Units (there are 5 within the NRR), Landcape Units (there are many within each Population Unit).
Workflow: I want the user to be able to...
  1. View data at the NRR level, which works fine with current bookmark settings
  2. Select a Population Unit to zoom to, and view different themes at that extent without returning to NRR extent - does not work with current bookmark settings
  3. Select a Landscape Unit from a list, which will then open a new page with specific stats related to that Landscape Unit. I also want the user to be able to view different themes at the Landscape Unit extent without returning to the NRR extent - does not work with current bookmark settings
Why Bookmarks vs. Layer List:
I understand that the layer list would technically allow different themes to be viewed by turning layers/groups on and off, but in conducting user testing for this app, my users find this confusing given that the layers will cover each other - ie. it is not intuitive to them that layers higher in the list cover layers lower on the list. As this app is designed to serve the public eventually, I want to make it as user-friendly as possible. Having bookmarks would be much more user-friendly if the "zoom to extent" component could be toggled off.
Other efforts to work around:
Using a List to allow the user to zoom back to the Population Unit / Landcape Unit in question: since much of my app uses Selections to generate stats specific to a given Unit, this is not viable, because the list will unselect something that is already selected if it is clicked again.
Map  Actions: I've tried setting map actions so that the maps will zoom to a certain extent, but the bookmarks override these actions
'Zoom to selection' option on Map Widget: the users do not notice or know to look for this option in user testing / I can't move it to a more noticeable place on the screen or really alter it to make it pop
My other option seems to be just making 7 different maps, which is probably what I'll do in the meantime.
3 Comments
TaraHaynes
I poked around and discovered that you can add a source map to Data multiple times, and then set layer visibility from there:
With that, you can use multiple views + map widgets to display themes without any dependency on extent.
However, I think that being able to do this type of workflow with bookmarks would be a lot cleaner, particularly as it would allow you to everything on one map widget and be a little less cluttered on the backend. But, I am happy that I don't have to make 7 different source maps!
Lake_Country_GIS
Hi Tara,
You can also just create a copy of the Bookmarks Extension and comment out this line:
    if (appMode === AppMode.Run || appMode === AppMode.Express) {
      if (jimuMapView && jimuMapView.view) {
        jimuMapView.view.goTo(
          //this.Viewpoint.fromJSON(viewpoint),
          gotoOpts
Works like a charm. Will add this to the Experience Builders feature request at some point.
TaraHaynes
@Lake_Country_GIS Hello! Is this only for the Developers Edition? Unfortunately, due to the limitations of my organization, I'm not currently able to host my own deployment of ExB, so I'm hoping for an out-of-the-box solution!
