Allow Splash Window as a "window" Input for Buttons and Links
923
05-23-2025 07:42 AM
Status: Open
Agrizz
I am attempting to add a button in the Header labelled "Terms and Conditions" that would open the splash window which outlines the application's terms and conditions. This is intended to allow users to re-review the Terms and Conditions without needing to exit the app.
Currently when configuring a button and going to the "Set Link" then "Windows" options, the Splash Window is not an option. The Terms and Conditions can be linked to ONLY if it is not set as the splash window.
EDIT: Currently working around this by duplicating splash page (as described below), would prefer to not need to duplicate though.
2 Comments
NicoleJohnson
You might've already thought of this, but I would just duplicate your terms and conditions splash screen window, then have your header button link to that. If the actual content changes, just delete the duplicate window, duplicate the updated window, then re-set the button link.
Agrizz
Hey @NicoleJohnson , thanks for pointing this out. Yes I did figure that out and am currently doing this. More of a small quality-of-life change than anything. I've updated my post above to reflect this workaround.
