Allow Arcade Expressions in Experience Builder
43354
65
05-13-2020 08:52 PM
Status: In Product Plan
ZorbaConlen1
It would be useful to be able to use arcade expressions in the following areas:
  • Filters. The list of fields available to filter on should include any arcade expressions created for the layer.
  • List templates. Again, really useful to use Arcade expressions to enhance data presentation in list widget.
  • Image and text widgets.
I'm hoping to see this extended in future releases of ExB. There are probably other widgets and interfaces where it would be useful as well within ExB.
Thanks
65 Comments
DavidTreering1
@ShengdiZhang please read the above comments requesting details of the implementation.
This is even more confusing that a feature went backwards from 'Implemented' to 'In Product Plan.'
ShengdiZhang
@DavidTreering1
Hi, the remaining issue with this idea is support for Arcade field expressions in widgets. We’re currently planning to add this capability in an upcoming release.
Please let me know if you have any other requirements related to Arcade support.
Pukawai
Yes, include Data Expressions as sources for List widgets.
ShengdiZhang
@Pukawai Hi, You can add Arcade data from the Data panel, and then select it in the list widget.
You can find more details at https://doc.arcgis.com/en/experience-builder/latest/build-apps/select-data.htm#ESRI_SECTION3_1DD4154...
RandyMcGregor_BMcD
Thanks! I don't get notified when comments are added, so I didn't realize you had posted this.
