Great recent improvements on the elevation profile widget - thanks!
Our clients need to use feet for the X axis for the graph and the exported data from the graph.
Experience builder is defaulting to miles on the X axis. It can be changed by the user in settings each time the app is loaded or reset, but it would be so much more efficient and logical for the custom app default units to be set by the app creator.
Please provide default unit setting options for the elevation profile widget in Experience Builder.
I just realized the elevation profile widget has a profile settings panel which includes default graph units. It works great!!
Hi @BruceRiesterer ,
Thank you for posting this idea!
Please take a look at the configuration options under Profile Settings for the Elevation Profile widget: this is where the default units can be set so that users do not need to change them again every time the app loads.
Is this the functionality you are looking for?
Thanks Alix. Hats off to ESRI for outstanding improvements to this widget!
