Add Calendar Widget
18360
39
08-31-2020 11:49 PM
Status: Open
TiiuKelviste
Would be nice if Experience Builder would have a calendar widget (a classic display of month and dates) that you can connect with your data that has date-time information. This would be extremely useful for example to show events from a certain day. Right now you can only use a list to display events but to connect it to a simple calendar view would be really nice.
Tags (1)
39 Comments
Megan2
I was also googling about this and would love to see it happen!! Maybe a calendar widget where it either focuses on current or manually set to a specific date range such as a past month or future, like for an upcoming project or event. And maybe have the option to link data to it as other people mentioned, or just leave it without linked data to simply show the date for context.
BrianGallegos
Another Googler here.  My hopes were so high but were dashed when I realized it was only an idea.  This would be so helpful for my facilities maintenance people to see their work orders not just spatially, but calendar-y.  Spatial/Temporal match made in heaven?
cat206
I noticed the calendar widget in the recent ESRI UK Conference (Powering up your field mapping with Arcade) , and wanted to try and find out which one it is - does anyone have any idea please?
TimWestern
The Calcite Design system does have a 'date picker' that can display a calendar
https://developers.arcgis.com/calcite-design-system/components/date-picker/
I've not seen the widget that @cat206 is referencing, if if someone didn't show me that it was a new widget coming out for use, I'd have presumed its actually a custom widget that has form fields for date and time for start and stop, uses a calendar picker at the bottom, and  reset and today button.
(Note it is possible you might find a similar design element used elsewhere that's free to use or open source somewhere that does similar things, date pickers have definitely been around for a while in Web UIs for as long as I can remember.)
(also beyond which section is on top, it may be that the sections for the map and table and the section for the chart are not quite matching border to border/side to side, and that might be an issue with the layout used)
SIGNormandieDev
Très bonne idée,
J’ai moi-même eu besoin de cette fonctionnalité pour l’une de mes applications.
J’espère que cette idée sera retenue.
LucianoLupedia
I believe it would be greatly appreciated to have a calendar that highlights dates with any actions or reports. This would allow users to check what happened on each date or filter for dates with reports only.
CarolinaAguilar
This widget would be very useful for our organization
TimothyHutchison1
Yes!  This is no-brainer!  We've been wanting this for a long time now.
JeffreyLenard
Creating this tool is essential, as it will seamlessly complement a wide range of ESRI products. Our organization has been eagerly anticipating this feature for quite some time. Its introduction promises to significantly enhance our data visualization capabilities and boost efficiency. We believe it will have the same impact for countless other ESRI customers, making it a highly anticipated and logical addition to the ESRI toolkit.
edward33
this would be amazing! I would love an addition like this
