Add a Global “Clear Filters/Selections” Control
1649
7
11-26-2025 07:01 AM
Status: Open
MappingAnalyst
In ArcGIS Experience Builder, filters and selections made within a Feature Info widget can currently only be cleared using the small Clear Selection button in the widget’s top-right corner. When an app contains multiple Feature Info widgets across different panels/views, users often leave filters active without realizing it. As they move through the app, they may become confused when expected features no longer appear.
I’d like to request a global control (a widget or button) that clears all filters and selections applied across Feature Info widgets (and potentially other widgets). This would help users reset the app’s state without needing to manually clear each widget or refresh the page, which resets the map extent and interrupts exploration.
A global “Clear All Filters/Selections” option would significantly improve usability for apps with multi-panel workflows and multiple Feature Info widgets.
7 Comments
JeffreyThompson2
Not exactly a full solution to your request, but the Clear Selections Buttons within the Select Widget should clear selections made from any Widget.
DavidL
This is an often requested feature indeed!
BenClark
I'd love to see this too. Right now, the closest I can come to this functionality is to add a button that essentially reloads the entire experience. It'd be cool to not have to go nuclear like that though.
BrantSollis2
Another upvote for this feature.  Experience builder can do awesome things, but sometimes users get overwhelmed or confused by selections when changing views for example.   I use the global clear selection button in ArcGIS Pro all the time.  I'd love for ExB to have something similar.
LARAPAdmin
@BenClark Did the same thing. I had a request to have a global reset filter and the best thing I could think of was to add a button that reloads the ExB page. It has been working but would prefer a configured clear all option instead.
TonghuiMing
Hi all,
The function has been supported by using the "Clear data filters" and "Clear data selection" actions in the recent AGOL 2026 June release (and will be included in Enterprise 12.2).
Try using:
Button widget > Button click -> Data > Clear data filters/Clear data selection
BogdanPalade21
@FTong it does not work as expected, If a chart has filtering actions defined (on selection) the "Clear data selection" does not work, not even in conjunction with "Clear data filters".
