What's New in ArcGIS Experience Builder (October 2023)
3091
9
10-31-2023 10:09 AM
Jianxia
The new Analysis widget consolidates capabilities from two Web AppBuilder widgets – Analysis and Geoprocessing. The Near Me widget is now out of beta. Other highly anticipated improvements include pop-ups showing on the map when the user selects features in another widget, multiple Map Layers widgets with custom layer lists connecting to a single map, the Edit widget supporting editing related records, the Table widget allowing the user to set filters with SQL expressions, and a new Extent navigate tool for the Map widget. Read the blog post for more information.
Cheers,
9 Comments
leahmaps
Do the analysis/geoprocessing widgets consume the organizations (who owns the Exp. Builders) credits?
JwHayes
@Jianxia, will we be able to edit multipoint features in the new editor widget?
Jianxia
@leahmaps , if you use your own geoprocessing tools published from ArcGIS Server, no credits are consumed. If you use Esri built-in tools, credits are consumed.
Jianxia
@JwHayes , batch attribute editing is not yet supported.
JwHayes
@Jianxia thanks for the quick response. I'm not sure we're talking about the same thing. I'm referring to the Multipoint ESRI Geometry type. https://developers.arcgis.com/documentation/common-data-types/geometry-objects.htm
Jianxia
 @JwHayes. thanks for sharing the link. Editing multipoint feature is not supported yet on the web. Your request has been added to a backlog issue.
JwHayes
@Jianxia  Thank you!! 😊
MaureenSpiessl
Will this update effect the loading of the maps on tablets and iPhones?
rachelm
@Jianxia is there any ability to select specific map features to run as input parameter, instead of the entire layer?
Contributors
About the Author
Product Manager for ArcGIS Experience Builder and ArcGIS Web Appbuilder. She likes camping and hiking.
