ArcGIS Experience Builder Developer Edition 1.20 Is Here
2212
9
04-13-2026 09:51 AM
Labels (2)
Jianxia
Version 1.20 of ArcGIS Experience Builder developer edition is now available for download. This version brings new widgets—Date Filter and Theme Mode Switcher, Arcade assistant (beta), and other highly anticipated improvements from the February 2026 release of ArGIS Experience Builder in ArcGIS Online. For developers aiming to integrate Experience Builder apps with other applications for seamless data sharing, we’ve introduced postMessage support—making cross-app communication easier. Let’s dive into these developer-focused advancements and see how they can elevate your projects
Share Data Between Apps
Integrating an Experience Builder app with other applications can improve workflows and create unified user experiences. You can do this in two main ways:
  • Iframe—Embed an Experience Builder app into another site, such as an internal portal or public webpage.
  • Embed widget—Embed another app (e.g. ArcGIS Dashboard or third-party app) inside your Experience Builder app.
Two-Way Data Exchange with postMessage
Previously, you could only pass data into Experience Builder using URL parametersone-way communication. Now in version 1.20, postMessage enables two-way communication:
  • From Experience Builder → to the other app.
  • From the other app → to the Experience Builder app.
How to Enable postMessage
  • Incoming messages: Add ?post_message=true to the Experience Builder app URL.
  • Outgoing messages: Add ?listen_message=true to the embedded app URL.
Types of Messages Supported
  • Authentication
  • Data records and filters
  • Page/view navigation and window status
  • Map and extent
For sample code and details, see the Integrate with other apps topic.
Breaking Changes – Read Before Upgrading
There are breaking changes that may affect your apps. For example:
  • DataRecord: getId() now returns string | number instead of just string.
  • DataSource: New getUniqueIdFields() method returns the data source’s unique ID fields. If both object ID fields and unique ID fields exist, the unique ID fields take precedence.
Review the breaking changes before upgrading to avoid potential issues.
Additionally, for offline installation, you can now download the Node Cache package for version1.20.
More Resources:
For more information about the 1.20 release, see What’s new. You can reach us at  experiencebuilder@esri.com.
Thank you,
The ArcGIS Experience Builder Team
Subscribe to our newsletter to receive the latest ArcGIS Experience Builder updates, news, and content.
9 Comments
JeffreyThompson2
MVP Frequent Contributor
I am curious about the two-way message communication is this intended to only be between Experience Builder applications or is it setting up support for further Dashboard/Instant App integration?
Jianxia
Hi @JeffreyThompson2, Two way communication supports any web apps. There are no plans to support further integration with Dashboards or Instant Apps.
JJChen
Does arcgis portal 11.5 support arcgis experience builder developer version 1.20?
JJChen
The three empty boxes are Zoom and Home tools in the Map widget. ArcGIS Enterprise 11.5. I tried ArcGIS Experience Builder developer version 1.19 an 1.20, and saw the same empty boxes issue. If I use the hosted ArcGIS Experience Builder in ArcGIS Portal, then I get the normal Zoom and Home tools. Why?
JJChen
I will call the Technical Support tomorrow.
Jianxia
@JJChen, thanks for letting us know. ArcGIS Enterprise 11.5 should work with the dev edition if you just import the app from 11.5 to the dev edition. Could you please share the support case for us to follow up? Thanks!
JJChen
@Jianxia The ESRI case number is 04173576. After our GIS administrator turned on the option "Allow anonymous access to ArcGIS Portal", and removed the domain https://js.arcgis.com from the trusted server list in our production ArcGIS Portal, every thing is working now. Thanks
Jianxia
@JJChen, thanks for the update!
JeremyDew
@Jianxia any ideas why when downloading an app from ExB Dev Edition 1.20, the "arcgis-portal-components" folder is not being included in the .zip file?
It seems the Analysis widget is dependent on this folder/files, so when publishing the app to our web server the analysis widget does not work. Manually adding the arcgis-portal-components folder to the zip file fixed the widget once the app is published to the web server.
Contributors
About the Author
Product Manager for ArcGIS Experience Builder and ArcGIS Web Appbuilder. She likes camping and hiking.
