A Patch for Version 1.8 of Developer Edition Addresses a Regression Issue
1146
04-29-2022 05:04 PM
Jianxia
A patch is available here for the developer edition 1.8. It addresses an issue that a feature layer from a map service does not respond to the feature filtering or selection. For example, the selected feature on the List widget does not get highlighted on the map, or the Filter widget can no longer filter the data. As this is a regression issue, we would strongly recommend installing the patch if you are using the latest version 1.8 of developer edition.
Here are the steps to install the patch:
  1. Download the repository code and unzip it.
  2. Browse to the patch directory (patches/1.8/patch1/arcgis-experience-builder)
  3. Replace the files in the client folder on your Experience Builder installation with the files from the patch.
  4. Run npm ci in the client folder
  5. Restart the node server in both client and server folders
Let's know if you run into any problems. Thank you.
1 Comment
About the Author
Product Manager for ArcGIS Experience Builder and ArcGIS Web Appbuilder. She likes camping and hiking.
