Workgroup ArcSDE and enterprise ArcGIS Server?
2745
04-16-2013 08:09 AM
xiannianchen
Hi, guys,
I have two questions about Workgroup ArcSDE and I don't know they are related or not.
Our ArcGIS Server is at Enterprise level, and I have Workgroup ArcSDE through SQL Server Express configured on the same machine. The ArcSDE license/authorization file I used is the same as the Enterprise ArcGIS Server. The Workgroup ArcSDE authorization process went through without any problem.
The first question: Can I configure Workgroup ArcSDE under Enterprise license level?
The second question is: I can create a geodatabase by using the Database Server node at ArcCatalog. In the built connection, there is a command for "New Geodatabase" when I right-clicked. In the popup window, it lets me type in the Geodatabase Name, specifying the location of the storage, the size of the storage, and so on. After clicking OK button, it takes some seconds before the geodatabase name shows in the connection. But the geodatabase name disappears when I hit the refresh button, and the storage file is not created at the location I specified. I don't know why. Is it a bug from ESRI, or different licence level between Workgroup ArcSDE and Enterprise ArcGIS Server?
Mike
DerekLaw
Esri Esteemed Contributor
Hi Mike,
A1. As referenced in the other thread in Domenico's post above, an ArcGIS for Server enterprise license will NOT work to authorize a Workgroup ArcSDE for SQL Server Express instance.
A2. This behavior occurs because the geodatabase was never actually created. Yes, this is a known bug (NIM083155) and is fixed in the forthcoming 10.2 release.
Hope this helps,
