WMS Mappings
2764
04-01-2016 12:46 PM
ElizabethNolan
Does anyone know where the parameter is grabbed from to set the values for the WMS xml? Example, the value is pulled in for WMS_Capabilities, and a xlink:href=, and if you are on an internal endpoint and you select a mapservice and click WMS, the mappings reflect that server. If you select the same service on an external endpoint then the WMS service reflects the external server, so I know that the values are not static but dynamic.
So I am wondering in what file is that value being pulled from?
Any ideas?
Thanks!
