Why? Sync is checked, but layers are references in distributed collaboration
2422
02-29-2024 05:57 PM
AmyRoust
I have a two-way distributed collaboration between ArcGIS Online (host) and ArcGIS Enterprise Portal (version 11.1). I published a feature layer with data from an enterprise geodatabase to Enterprise Portal. I made sure to check "Enable Sync" in the feature layer properties before publishing. When I share the layer to the collaboration, it is always referenced instead of copied. WHY?
AmyRoust
I finally found the issue! When publishing a service that you want to have copied instead of referenced in your collaboration, you must ensure that the following fields are visible in your table:
created_user
created_date
last_edited_user
last_edited_date
GlobalID
I was hiding some or all of those fields in every service I published. The annoying part is that if I made those visible and used the overwrite service option, it did not immediately switch to a reference. That wouldn't happen until the automated sync occurred (we have it set to go at midnight every night).
I hope this saves people some headaches in the future.
TimoT
Hi @AmyRoust,
There are additional steps required to share feature data sourced from an enterprise geodatabase across a distributed collaboration.
Check out the Esri documentation below:
Timo
AmyRoust
Thanks, @TimoT! I'm in compliance with everything on that page. I've got a ticket in with Esri Tech Support now. We were on the phone for an hour and 15 minutes yesterday with no resolution. Fingers crossed that we figure something out!
AmyRoust
created_user
created_date
last_edited_user
last_edited_date
GlobalID
