Why my definition query does not work in Server 10.1
1227
05-20-2013 09:30 AM
JoeFlannery
Honored Contributor
While migrating map services from ArcGIS for Server 10.0 to 10.1 I discovered something interesting that I thought important to share.
We use many of our map services in ArcGIS Explorer Desktop 1750.  When served from AGS 10.0, these map services appeared and performed properly in AGX Desktop.  When we migrated (re-published) our map services to AGS 10.1, some of our map services did not work in AGX Desktop (but did appear and work in ArcGIS Online).
We found that if a featureclasses in the published map contained a definition query and the definition query contained a 'space' in the wrong place, the map service would not appear at all in AGX.  This only holds true for services on AGS 10.1.
For example, this definition query works on AGS 10.0, but not 10.1:
  (Milepost %10= 0) AND Date_End IS NULL
This definition query works on AGS 10.1:
  (Milepost%10= 0) AND Date_End IS NULL
The space between the field name and the percent sign was the problem.
nicogis
However you have to help the system because '%' is Wildcard - Character(s) to Match but also Modulo so the system can confuse if you don't delimite field, space between % ect.
